Sheetmetal Question
Ray in CT
Is there a difference between the front grille/cowl, and the hood from an H to an M. Meaning can I swap out a good hood and cowling from an H to my M without it taking away any qualities?
such as grille fins or size. etc..
They may look alike, but they are a high quality example of part scaling (as are the engines etc) there is no compatibility. Put an ad in the classifieds, or look for the right parts. Sorry, Jim
Ray, As noted by Jim they are both different in size and will not interchange. The easiest way to tell the difference of the grill to me when not on a tractor is by the location of the cultivator brace round holes near the center upper part of the grill. On a "H" they are both above the first wide bar at the top of the grill while on the "M" they will be below the first bar. Hope this helps in finding what you need, Hal.
GO stand beside each one and take note of the height and width of each one.that should give the answer you need.
