Sherman bent ram
Goofed up and bent a hydrualic ram on my Sherman backhoe (on my '55 Ford 641).
Still works...up to the bend. I called around to several hydraulic repair shops and their advice to to buy a whole new cylinder at TSC. I looked and mount at the bucket seems unique to the sherman rams. I have not seen anything at TSC or Farm&Fleet that would work. I'm in southeast Kenosha, WI and work in the Chicago, IL area. Any suggestions on where to get the beast repaired or replaced? Thanks, Jeff
chrome was in sad shape on my hoe bucket cylinder, hydraulic shop had machine shop cut end off and weld it on new chromed stock
they then rebuilt the cylinder, worked just fine but wasn't very cheap
you might find something close online at "surplus Center", the kind of cylinder you need is most expensive type
Do not retract it past the bend. What you'll do is cock the piston and it will gouge the barrel. I have straighened a rod on a 4 ft cylinder using a hydraulic press. It takes time and trial and error but can be done. The alterative is to take it to a cylinder shop and have it re-rodded.
Good luck
LOOK on Surplus center.We replaced the lift/and dump cylinders on our 706 Swartz Loader.If necessary to have the correct ends. it is possible to cut off new ends on the new cylinders, and the same on the old .(power band saw) then re weld the old usable ends to the new cylinders. Just make sure the pin holes in the old ones aren't worn out. We made NEW Tangs to weld on .the old ends(tangs) were worn so badly it would take more time to repair then make new, The holes were so badly worn out and ovaled, we had no choice but to make new.
Hope this information helps. Like the fellow said "DO NOT RETRACT THE CYLINDER ROD. Sure will bust and ruin the chance to rebuild/straighten.
REGARDS LOU.
hyd cyl here
Cylinder repair service....N of O'hare or Hydraulic Pneumatic Corporation
Quality commercial repair service is done by both.
worse comes to worse and it will probably scar cyl where it will leak some,but I have taken a chain put it around both ends and jacked them straight with a 20 ton jack.take it to a machine shop and they could probably press it straight enough to get you by until you find one.
If it was mine,I"d pull the pin at the end of the rod,turn the shaft 180 degrees,replace pin-use a hydralic jack between the boom and shaft and slowly straighten it back.
Just my thought Al
Chromed steel cylinder shafting is READILY available and any hydraulic shop worth a $*@^ can easily repair that cylinder.
I have taken more then one hyd cylinder and put it in my pipe bended to straighten them up and so far I have done real well doing so. One like that if you flip it at the pin may well fix its self over time
Bent one about like that in an old 580 CK; wasn't any trouble to straighten it in the shop press, but...........it wouldn't stay straight. First time I 'hung' it on something, it bent again. I'd say you're better off replacing the shaft.
Thanks for everyones replies and input. It seems like the best long-term solution is to take it to one of the places reccomended (Ohare is fairly close to my business) and have them cut off the end of the bent ram and reattach it to a new ram using the exiting cylinder. This beast is 56 years old--I'm trying to get it positioned for another 1/2 century of life.
No--I moved our 5' x 8' chicken coop (which is wheeled on one end) 200' across our yard. Instead of elbo grease, I strapped the logging chain between the un-wheeled end of the coop and the bucket so that i could lift one end and pull at the same time. It all seemed to go fine until I arrived at the desitnation and saw that I had torqued the ram in a way that it was not designed for. Bummer.
Being a machinist I put a new rod in one of the cylinders on the loader of our 165. The rod was scratched so Dad ordered new rod from Bailey's if I remember correctly.
It was 1/2" short, but it was clearance so we made due. I made up a new end that was a 1/2" larger in diameter and just drilled it off center to make up the extra 1/2". Was gonna do the lathe work on the other end myself, but our lathe operator offered and had it done for me within a very short while.
Once he had it turned I welded the end on, rebuilt it with new packings and o-rings, and did it all for around $50. Don't remember exactly. The rod was about $25 or so, and one of the components inside was kinda pricey.
Donovan from Wisconsin
