Sherman Combo Transmission
No, there is no Sherman or any other forward mounted aux trans that will work with the 5 speed.
are you looking to speed up or slow the tractor down? i have a everrett transmission that came of 800 ford 5 sp but it only slows down tractor.
too bad someone couldn't mod the input shaft ont he *5* models to work, since it doesn't have live pto.. you'd think it would be the same as a 3 or 4 speed setup.. or could be done similarly anyway.. might be a fun.. though expensive project..
soudnguy
As I recall the input shaft on the *5* is not as long as the input shaft on the *4* transmissions so there wouldn't be enough room inside the bellhousing for the Sherman to fit in there.
i wonder if custom machining on the sherman input shaft could be accomplished to shorten it up a tad? all academic speak.. as I don't own a lathe.. just thinking out loud.. :)
soundguy
(quoted from post at 08:58:21 01/18/11) i wonder if custom machining on the sherman input shaft could be accomplished to shorten it up a tad? all academic speak.. as I don't own a lathe.. just thinking out loud.. :)
soundguy
Won't work. The 5 speed bulges forward in the bell housing and there is no room at all for a sherman to be tucked in.
