If your original question related to "tilling" means a PTO powered roto-tiller, then a step-down auxiliary transmission would not help because the PTO speed is related to the rpm speed of the input of the transmission, and the Sherman replaces the input shaft on the transmission, so using it in step-down mode would slow down everything inside the transmission, including the PTO. Even if you could make it fit, the 850 with non-live PTO would have the same problem, and it flat out wouldn't work in an 860 due to the dual input shafts for the live PTO, as the Sherman has no way to accommodate the dual clutch and dual input shaft of the 860, so it wouldn't have any power to the PTO at all.So I’m willing to do whatever is necessary to make this happen. Is it possible to machine a Sherman to make it work or is it so far off a new case would be necessary?? I’ve read the step downs are rare and also that they slow down pto… so maybe the Sherman isn’t the way to go anyways… also wondering if I can modify first gear and just replace it as I only use 2nd for regular work anyways
Just about anything is possible with enough money and or time, but what you suggest is simply not cost effective.So I’m willing to do whatever is necessary to make this happen. Is it possible to machine a Sherman to make it work or is it so far off a new case would be necessary?? I’ve read the step downs are rare and also that they slow down pto… so maybe the Sherman isn’t the way to go anyways… also wondering if I can modify first gear and just replace it as I only use 2nd for regular work anyways
You may have to till a little shallower and make more than one pass. Otherwise the SOS transmission has slower gears than the 5 speed while maintaining the same pto speed. But that involves a different tractor. The blue SOS transmissions (early 4000 and beyond) are considered very reliable and do not have the freewheeling gears that the 871/881 tractors had. I do like the SOS transmissions. It gives the vintage Fords 10 forward gears and the ease of shifting similar to a more modern tractor. I have a 3000-D SOS, early 4000 gas row crop SOS, and a 5000-D SOS. The SOS is nice in a hay field.Hey all,
Just wondering if a Sherman step down would work on my 801 5spd?? Or anything similar. I’d like to go a little slower while I’m tilling. Thanks
Should I look for the 10 speed sos and stay away from the dual range 8 speed??
I do not recommend an SOS tractor.Looks like most your opinions are to upgrade to something newer considering the cost so I’m going to abandon that project… looks like a good idea considering what I can find for sale is pretty reasonable. I’m interested in a 4000 unless there is something else I should be looking for.. I’ll take any suggestions. Is gas vs diesel just a matter of preference? Should I scout a 10 speed sos or is the 8 speed dual also ok?? Should i consider something even newer I’m not aware of?
