Sherman step up trasmission
IH Guy
Freind of mine is working on his 48 8n step up Sherman transmission. Had the cable shift and it continually popped out. Could adjust the cable either way and it would pop out. He is going to covert it from cable to lever shift. Not sure if this will help or nor. The unit he has does not have a detent ball and spring. Tore into it and there is a little wear on the fork and the gear assembly that engages and disengages the step up. Anybody have any insight. Anybody have contacts as to where you could get parts or send in to have repaired? Any help would be appreciated.
