shifter rubber dust cover
bs2359
this ia probably a simple question to most of you fellas, but how do i replace the rubber dust cover over my shifter? I have a 1960 D-17 S 2. Do i take out the shifter to
accomplish this task, if so how? I cannot take the rubber knob off for fear it will ruin it. Thanks,
Well then, you're just going to have to buy a new rubber knob to go with the new rubber boot. The boot goes on over the top with some window cleaner for lube. You are far better off with a good rubber boot (to keep water and dirt out of the transmission) than a good rubber knob. In fact, running without the rubber knob may help keep one from grinding gears because it might hurt the palm of your hand !!!
thanks doc!I really did not expect that answer, but I guess I am understanding it would be a huge job to remove the shifter rather than the knob. I would also bet that purchasing
a new knob would also be easier and less expensive?
