Short / long frame B?
More short frames made, but earlier tractor, and some of the earliest are rare. Less long frames made, but later more "common" tractor. Up to you.
The Long Frames were ONLY late 37 and 38 while the short frame were all (more made) others. However the real early 4 bolt B's (1st 2000 made I believe??) or brass tag are prob worth the most.
Heres my 38 Long Frame
http://inlinethumb50.webshots.com/47409/2180141330095401896S500x500Q85.jpg
John T
John Ts Long Frame B
Sweet looking tractor John T.
I hope my '38 long frame looks that good someday.
I'm starting the reassembly. Still looking for a pair of front wheels.
What kind of paint did you use?
Kurt
My buddy did the painting, he used Classic Green from Mother Deere + hardener is all I know??? I did the mechanical but I cant paint.
The pictures are on Webshots under either John T's B or John Nordhoff somewhere, I took several
http://travel.webshots.com/album/554031836ecRtCj
PS the daughters interview got changed to next Monday so looks like she wont get a chance to visit. Who knows where she will end up, were hoping she stays close in Indy but she may like Raleigh?? If so Im sure we will visit someday
John T
John Ts B
John T,
Sorry I"m going to miss your daughter, but if it all works out for her here, for sure we will get to visit. Bring your banjo!
I"m going to try my hand at painting my "38 B. I guess if it doesn"t work out well, I can always do it again.
Kurt
Gentlemen thank you for the input. After reading your posts I'll be keeping the short frame tractor. I found out it has the brass serial tag.
(quoted from post at 05:38:40 07/11/11) The Long Frames were ONLY late 37 and 38 while the short frame were all (more made) others. However the real early 4 bolt B's (1st 2000 made I believe??)
If you don't mind me asking what makes a 4 bolt b a 4 bolt b? Are they only 4 bolts holding the frame to the crankcase?
I am just curious that's all.
A 4 "bolt" B is where there are only 4 studs/nuts holding the steering pedestal to the front frame. They are much more valuable since Deere switched to 8 studs/nuts in February, 1935.
