I am trying to repair a floor / pole lamp. The pole from the base to the lighting fixture is composed of 2 sections and connected together with a shoulder nipple. The pole sections are steel, but the nipple appears to be aluminum. The threads on the nipple have stripped out and no longer hold the 2 sections of the pole together. The lamp was made in China and emails to the marketer have gone unanswered. Online searches for lamp parts have been unsuccessful. I believe I have a plumbing / pipe related problem even though it relates to a floor lamp. Since the lamp was manufactured in China, I presume the nipple is a metric fitting. I am not equipped to furnish metric dimensions, and have been unable to discern the nominal size vs. the actual size from the web sites I have searched. The dimensions of the fitting in inches are as follows: inside diameter- 1.025", outside diameter- 1.180", shoulder / pole diameter-1.250", overall length-0.935", threads are parallel, pitch- 1.5 metric, 5 threads per 0.250". Consider these dimensions approximate as my arthritis hinders accuracy. If you were to search one of the major hardware suppliers such as Grainger, MSC, or McMaster Carr, how exactly would you describe this fitting? What would the specifications be? All I am trying to do is match the threads. A shoulder nipple would be nice, but a conventional nipple would work fine. Thanks in advance.
