Shutter or no shutter??
bruster
My dad and I are finishing up another JD "H"
It had a canvas shutter originally, but since I never run em hard, do you think I should install one? I don't plan on selling and it would seem to be a waste of material, if it's gonna be just rolled up out of the way
What do you guys think?
I'm not real familiar with the "H" do they have a thermostat? If not yes I would put the shutter back on and use it. You even said you do not run it hard. Even better reason to get it hot faster. I have a old "A" and I block the rad to get it up to temp. If not it takes a while for it to get up. Its always better for a engine to get up to temp ASAP.
I second that, I would definitely put the shutters back in. If your not working it hard its already going to take forever to get up to temp. With the shutters on it, it may make you reach operating temperature more quickly. The faster you get up to 190 and stay there the less fouling problems you will have. What year of JD H do you have, our H is a 1946 and it has the mechanical shutters?
This one is a 41 with a canvas shutter, We will use it to cultivate corn (long slow boring rows) I follow my dad's lead when it comes to operating Deeres. Work em, but don't overwork em.
My dad's H has mechanical shutters, that had to be freed up after a repaint, and he's never used them. He's had it for 42 years and it's a 43
Jason, the H has no thermostat, they are equipped with a thermosiphon system that works well. The shutters act as a thermostat ao they could be brought up to a high enough temp to burn fuel for more power
If you are only going to use it in summer, and don't care that it's not "original", I wouldn't bother. We have a '45 H with metal shutters and only close them in cold weather.
Thanks for the input guys!
We will only be running it from spring to late fall (raking, cultivating, pulling a wagon)so I think we'll just button it up without the shutters
Thanks again!
Shutters or wish you had. Running to cool causes extra wear, watses fuel, reduces power and puts unburned fuel up the stack. Fouls plugs and soots up the engine too.
You may well get away with slipping an ordinary systel high flow thermostat into the upper water pipe/casting on the top of the engine. Works on the Lister CS engines.
