sickle bar 8n
akerns
sickle bar cuts good for around 20 ft than cloggs up my rpm's are up & teeth are sharp ant suggestions ford 8n new at sickle bar mowing
Is the grass is extremely thick & high , try running it in 2nd gear & cutting half a bar swath . How are you running the bar as to ground angle ? Make sure the guides aren't pointed down . Have them tilted up slightly to avoid digging in or gumming up with grass . You should get yourself an owners manual with operating instructions . Let me know if you need one . HTH ! God bless
Is hay falling forward in front of cutter bar? It should not. Is grass board making grass fall in ward leaving about an eight inch clean spot? It should. Is sickle bar in register,do the sections stop dead center of guard at end of each stroke? They should. Is cutter bar dragging too far back? They way we used to check was to take a long string, reaching from back end of pitman rod to outside end of cutter bar. With the string in line with the pitman the outer end of the cutter bar should lead one inch for every foot of cutter bar length. This would be six inches for a six foor seven for a seven foot. With out a more accurate description of what is going on,I have tried to describe the most common causes of your problem. If you can give more details, some of us may be able to pin point the action need to take care of your problem.
What are you cutting, what kind of sickle mower, and how are you setting it up that you can mow half a sickle bar length?
make sure guard ledgers & sections are adjusted so they have a gap no more than fingernail. Grass hay better to cut when dry not moist from morning dew. Get enough tractor speed so you see hay toppling back behind bar. When cutting downhill you need much higher speeds - be safe. Tilt angle bar up for less agressive cut. Also, cutter bar should be set-up so it sits a little forward of 90-degrees from tractor. Avoid cutting already cut grass - that will plug most times. Good Luck.
it]s a ford 515 sickle bar belt driven gap seems to be ok they do stop center of guard it may be too dragging too far back also should i angle the bar slightly up i'm cutting a hay field with alot of under grass thanks alot
"should i angle the bar slightly up i'm cutting a hay field with alot of under grass thanks alot" Yes,in fact you may have to raise it more than slightly. I would suggest setting the angle about level maybe a tad more. You can get to much tilt, and just ride over the grass. You might have to adjust the cutter bar to ride above the under grass. It is my thought you have to stay out of that dead under grass. Sometimes you think the grass is dry but that under stuff will be damp and cause headaches. A perfect set up mower is a joy to mow with. Also check guards for any burrs or bent or broken tips. I could show you better than tell you hope this helps. If a slight adjustment seems to help go a bit more. Some times I go from one extreme to another on adjustments. It just seems to be quicker to find that sweet spot. Ask if any more questions.
Adjust bar tilt angle with tractor 3-pt top link. You can still get an Operators Manual for that mower from New Holland. You should get this. good luck
You either need the manual OR a friend to help that has used a sickle mower quite a bit. You didn't say if you have single or double guards. We can't see if the guards are worn out. We can't see if you have serrated ledger plates. We don't know if you have smooth, serrated over, or serrated under sections. We can't see if your holddowns are correctly adjusted. We can't feel if you have about 25 lbs of weight on the end when lifting it. We can't see how you have the inner shoe adjusted. Get my drift?
Gordo.
I cut alfalfa with a New Idea 7' sickle bar on my 8N... the biggest thing I've noticed is that you have to drive very precisely in line with your last swath - you have about 6" of play either way, otherwise, you're leaving uncut hay, or you get the sickle into your cut hay and it plugs up immediately.
Once I figured that out, I can usually make it around the field multiple times without plugging. However, it's gonna plug some no matter how good everything is working.
Whatever you do, be super safe working on and around the bar. Turn the PTO off if you are going to leave the tractor seat for any reason, and be real careful about putting your fingers inbetween the knives, even if the mower isn't running - you can still cut a finger off by moving the knives by hand... They don't call 'em "three legged dog-makers" for nothing!
es
Cutting Hay with the 1950 8N and New Idea Sickle Bar Mower
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/D7EkFWjWZ1o&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/D7EkFWjWZ1o&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
