sickle bar on ford 8n
akerns
new at this when i"m mowing with a sickle bar do you leave the bar up off the ground or do you let skid plates ride on the ground also do you leave the hydraulic lever the small one under the seat in the up right position or down i know ones recomended when tilling
leave it in position control and keep your bar off ground some.Most of the dirt from rain splashing mud etc will be on the bottom couple of inches of plants and it will work like a grinder on your sickle sections wearing them out very quickly.Also some crops grow back better and faster when its not cut real low,Especially if your going into hot summer when heat stresses and things are a problem.Some plants like sudan,johnson grass can form poisons when its stressed right after cutting so you don't want to cut it much lower than 4-6", and not graze or bale it again until its a couple of feet tall.Also if your baling your hay it will dry faster and more evenly if its laying on some stubble off the ground so air can circulate underneath .One other thing if your new to mowing and want to eliminate some weeds,mow in the hottest driest part of the summer,generally august here, and you can kill more of the weeds in your pasture because weeds are stressed from heat,most grasses look dry but they just go dormant during this time, and if you mow just before weeds go to seed they don't have time to regrow before winter and set seed .hope this helps a little!good luck.
The skid shoes are to be on the ground at all times when mowing, they are adjustable for height of cut, A mower will NEVER work correct if you try to carry the bar, all mowers when you start to lift and that is what it would be thinking you are trying to do will lift the outer end of bar faster and higher than the inside end and you will never get a level cut. Anybody that tries to carry the bar when mowing needs to learn how to mow.
akerns,
I'm not at all interested in arguing with Jack on this matter. Lots of times guys find out from experience that there are better ways to do things than the books specify. Sometimes the specifics of the situation (mole hills, ant hills, lodged hay, etc.) dictate that you have to do things differently. But, having said that, here's another perspective.
I have a Ford 501 sickle bar mower that I use on my Ford 2000 tractor. Here's what the Operator's Manual for my Ford 501 mower says:
"The height of the cut is controlled by the position of the inner and outer shoe soles. Adjust the inner and outer soles by raising or lowering them on the shoe as desired."
"IMPORTANT: Do not attempt to mow with the inner or outer shoe sole carried off the ground unless a clipping wheel attachment is used."
I drop my sickle bar all the way down when I'm mowing.
Tom in TN
