Sickle Mower Value
Morning everybody. I might be going to a sale tomorrow where there's a Ford belt drive sickle mower that's going to be auctioned. I don't know the model number but it is belt drive looks to be 6' bar doesn't look beat up really but the pto shaft on it is real rusty. The owner said it worked good but he is trying to sale it of course and I don't know him. What would you guys bid on it? I don't want to over pay for something I'm not sure about. Thanks for any suggestions.
It just depends on where you're located. Around here, the only mowers that bring over $200 are NH 451's. If it was in good shape, had an extra knife, and hadn't been welded on, I'd open with $75 and go up to $250 if I really, really wanted it. I bought a nearly new IH 1300 a few years ago for $300, and it came with 4 new knives and a big box of sections and other parts. Just go with what your gut tells you, and don't bid over your self-imposed limit.
Mac
Below $500 if it?s well used, above $500 if it?s good shape and in season and others are looking.
The market for these is real wide open, you never know who else shows up. I bought a real nice one for. $200, I saw a real nice one go $40, and I saw a well used up beaten one bring $750.
It could be all over the place, there is no rhyme or reason.
Paul
I wouldn't open for $75 unless somebody else started it at $70! I let the auctioneer take it down until someone else jumps if or he starts looking confused why no one is bidding. Then I throw in a REAL low ball and work up until the number is out of my range. People are paying too much for old equipment these days. Whatever you buy, you are going to have repairs and even old parts are pricey when you figure in shipping.
It looks just like that one in the picture. I've got a Ford pitman arm one and a parts one also. All I use it for is cutting around my pond and ditches. I'm thinking if I go and its going to go cheap I'd fix it up just in case. Thanks for the replies.
Are you a good mechanic??? Have you ever worked with sickle bar mower? Do you have a really good gut feeling built in detector? Other than obvious stuff they can be rebuilt if not totally destroyed . Go for it big guy!
Yes sir I'm a good mechanic I have to be to keep my 4 old tractors and equipment running! I've only used the one I've got now but you know how it is with this old iron you can never have to much!
If it?s the older style with the pitman arm and attaching straps I see them go $100-200. If a later model of true 3pt. w/ pitmanless drive $250+. More often $350-500. Central Mn.
And more storage space! As others have said...the newer the better but if you are standing there and the auctioneer is calling, and you KNOW it is a good machine you have carefully looked over, then get ready to double your bid. It will be worth it. Have done it myself several times. Doubled my bid one time and ended up with an excellent portable gas powered air compressor. Got it for $309.oo and the machine is worth $2,100.oo.
If its a belt drive like a 515 it'll probably bring between $250 and $500 most times,they don't sell as well as the NH or JD mowers.Just check out the bearings,U joints that type thing and budget in a new belt and new sickle assembly if you want it to cut right.
A nice used balanced head mower could be a good buy at $550.00. Deduct $200.00 for the pitman stick. The stuck shaft is a problem since you can't run it to check for other problems, so I would deduct $100.00 for that. 6 ft. is a short bar but you don't give a hint of what you will use it for.
I've only seen one balanced head IH mower in working condition go less than $400 in the last 20 years - and I own it. I bought a nonworking but mostly complete balanced head fast hitch mower for $175 and was offered $250 while I was loading it.
Largely depends on where it?s at, a 6? mower might do pretty good in Ohio or Maryland but nothing in Texas or South Dakota. You should be able to buy it for a couple hundred most locations.
I clicked on the link that Mutt & Jeff posted ..... within an hour EBay sent me an email about that mower saying I could make an offer if I wanted. Is that called spying or what?
EBay does the same to me. If I click on an item just out of curiosity I get 'reminders' of item listing period is about over even if the item does not end up in my watch list. Such is technology today.
