sickle mower
TimPa
put all new (double) guards on my ford 501, and replaced all the knives. after running 15 hours or so, noticed that the knives all have turned up edges on them. it seems to still cut ok, but didn't have this problem with the single guards. the doubles were basically lined up with each other - don't bend well with hammer - maybe not malleable? any thoughts?
Most mowers,you set the guards ledger plate level with the cutter bar.i personally use a piece of square stock ,remove the knife assy,and lay my tool to check with accross the top of barand guards ledger plate.that will tell you how your guards need to be adjusted. they have to adjust or you cant set your mower correctly.when you slide the knife section back in,adjust each hold down as it slides under. Your knife back should be pushed forward by the wear plates ,and the rear of the sections should ride on top of it,tilting your sections down slightly in front.when the point on your section is lined up withe point of guard, you should have about 1/64-1/32 gap between rear of ledger plate on guard ,and knife section. just guessing it sounds like you may have your guards set too high.between the wear plate angling section down,holdown holding down on middle,and guards pushing up that could real easily roll the edges up on your sections in just a short time.i dont know what else would unless your cutting a whole lot of small saplings or something,but that wouldnt cause them all to curl up evenly i wouldnt think. if you had it set too low dragging in the dirt maybe.
