Side Shield Body Work
I've got side shields that have two problems.
  1. One small portion was bent over. I've unrolled it but of course now it has waves in the sheet metal. What can I do to get this back straight?
  2. The mounting holes for the sheet metal had been pulled and created a pucker. how can I press that back down so its straight
Should I be using heat?
The problem is the stretch. heat makes it easier to stretch. The only way that I can think oof doing such a small area is to cut the excees out leaving a small gap then carefully MIG or TIG it together.
Patience and practice. Heat it with a small tip a small area at a time then tap it back into place with a small hammer and backup plate. With heat you can actually crowd the metal back into place.
Isn't there a type of hammer that pulls the metal together rather than spreading it?
Yes, I have a shrinking dolly, which woks by putting slight wrinkles into the metal. I didn't mention it because I don't see it working on that narrow strip.
