Siezed engine oliver 60
cookster
I was wondering what guys are using to free a seized motor from sitting? Tractor was stored in shed for a few years and is now seized.
My son in law and grandson freed up an Allis Chalmers C that was stuck for about a year with uncovered exhaust. Used a 50 50 mix of ATF and Acetone dumped in the cylinders. Stuck the crank in it and hung
weight on the crank. Took about a week and it started to move ever so little. They kept working it until it would roll over completely. It smoked like a steam engine when it finally started, even though
they had pulled the plugs out and rolled it a bunch with the starter to try and clean it out. Starts and runs pretty well now. Good luck!
would need more info than that. it could be as easy as oiling the cyl's or a teardown. first remove sparkplugs and look at them and into cyl's with a light to see how bad things are. also remove valve cover to check that valves are free. if water has leaked into exhaust pipe , its a tear down. don't know if shed has a leaky roof or pipe had been covered? to prevent this stuck situation is to oil the cyl's when parking a tractor that will be sitting and not started. plus turn it over couple times a year. saves a big headache.
Not to rain on your parade...I wish you the very best. But if it was seized, the answer to your question will probably be: QUITE A BIT.
