For many years I used a Gehl silage cutter that made what I considered to be conventional silage. This year I started using an IH silage cutter, that seems to work well, but it cuts the silage MUCH finer than the Gehl did--almost into powder compared to the inch pieces I was accustomed to. Is there any advantage or disadvantage to having silage chopped so fine?
Too fine could cause digestive issues in cattle, esp. dairy cows. Takes more power as well. It should be cut so that the kernels are scored or cut such that the seed coat is opened...this allow for more complete digestion, yet still provides some roughage value. Changing the feed roll speed or and the number of knives will change the length of cut...should be easy to set.
Ben
Some choppers have a recutter screen. Remove it. They are mainly for ear corn and hay. My old IH chopper had a simple 'gear shift' for the feed rolls.Slow for fine cut,fast for coarser cut.
