silver diamond truck head
What are the pros and cons to running this head on a 301? I have found 1 cheap and was curious what has to be done to run it...can you run with stock domed pistons?
The truck head made a 10 HP increase on my 301 engine that has fire crater type pistons at 540 pto rpm on my dyno. At higher rpm, this head will create even more HP. They flow more air as well as raise compression.
