Simplicity 9528
Jim Linzy
I have a Simplicity 9528 / Allis Chalmer 5030, with the Toyosha S148 engine. My solenoid has went out and I'm unable to find it for the starter that I have. The starter that is on my tractor has been rebuilt previous but the PN that is engraved into the case is 69305, someone has scribes PN 151-318A on the it. Can the Allis Chalmer starter PN 3435016M91 actually be used on my tractor even if the starters appears pictorial not the same?
I can't answer your part number question, but if there is a local starter/alternator/generator shop near by, they can probably match any part needed at a fraction of the cost.
As for using a different starter, it is common for different starter manufacturers to make a starter for the same engine. If it will mount, have the same gear tooth count, same rotation, and not interfere with any other components, it should work.
That is another advantage the starter shop will have, they know about substitute parts and cross referencing, known problems and preferred products, price advantages.
