simplicty 16 horse
No good ideas. Which engine is in it?
Is there gas in the oil?
Do you have the equipment to do a leak down test and check to see that the valves are sealing?
What is the compression? This may not be a helpful number if the engine has a compression release.
If you disconnect the crankcase breather hose at the air cleaner, does it run better, but smoke there?
Remember, it only lacks 2 years being 30 years old.
