Simpson 3100psi pressure washer
sqweeky
Tractor supply had these Simpson 3100 psi pressure washer on black Friday sale for $199 , these were out of stock so I ordered one on line. Does anyone have any experiences with them? Thanks
I have a Simpson 3600 psi with a Honda engine. Works great on tractors, combines and implements……with the right nozzle. Any Honda engine make sure you shut the fuel off and let it run out of gas when you are done. They don’t start if you leave gas in the carb.
Sounds like a poor set up to not run if you leave gas in the carb. As for a gas powered washer I had one that didn't run and it is now someplace else. Never to have another one. Electric motor or a diesel to power one.
I have one. Also bought at Tractor Supply. Had it for several years now. Never had any issues with it, always worked OK.
Just shut it down as normal. No problems.
I have Honda engines on 3 pieces of equipment (log splitter, generator and leaf blower). All of them start very well after sitting with gas in the carb. I only use rec. fuel and I'm a firm believer in SeaFoam for resting equipment.
