Size threads on 48 8n tank?
MOmilkman
Can anyone tell me what the size and pitch is on the treads that the petcock threads into the bottom of the tank?
I m not getting fuel to flow through mine so I need to remove it. My tank is full and I don t want to drain it so I m going to stick a bolt in there real quick after I pull the petcock out.
Threads are 3/8" NPT (National Pipe Thread).
You would need a 3/8" pipe plug from the plumbing dept. at a hardware store or "home center".
NOT that I think what you are planning to do is a good idea.
May I suggest rounding up enough good, clean gasoline containers and siphoning the gas out of the tank into them.
BE CAREFUL, unless you are working outside any leaks or spills will turn to explosive gas vapor which is heavier than air and will hang around above floor level just waiting for for a spark or other intention source!
(quoted from post at 17:23:05 03/08/20) Threads are 3/8" NPT (National Pipe Thread).
Thanks Bob. I do appreciate your concern. It s on a concrete pad outside behind my shop so yes, not indoors.
Thanks for the info
