Skid tank with pump
JimS
I need a water skid tank with pump that slides into a pickup. Ideally, I would like 200-300 gallon tank with a pump that pushes 120 psi or so and has a hose reel. It would be great if it did not occupy the entire bed. All I can find are fire units and they are a little pricey in the $7500-$14000 ball park. Are there alternatives to the fire units? Any other thoughts or solutions without crafting one myself?
lots of guys use them 300 gal icbm tanks or they call them totes with the wire cage around them put a harbor fright pump on them 3 inch pump works best . we have them pumps on a fire dept tender and i have on at home the work great start first pull every time and you will have all the water you need . check with your local fire dept for some 1 1/2 hose that did not pass hose testing we give it away
Why not get a 250 gal. Tank that comes on a skid and just mount a pump and real.i would not even consider spending that kind money on a tank skid.the setup i mentioned can be completed under $300
