Skidsteer Tires
T_Bone
How many hours can you typicaly get out of a new set of skidsteer tires?
I'm seeing bald tires at around 1500hrs on used equipment and thought that's abnormal or run hours are not correct ???
I have no idea why the other thread posted as I deleted it???
T_Bone
I could see tires worn that quickly on a skidsteer used by construction companies. The spend a lot of time spinning around on concrete and asphalt. Even the ones used by landscaping places see a lot of parking lot duty clearing snow in the winter time if they are far enough north.
If you are on concrete all the time 1500 hours sounds good to me.
Dairy farmer friend of mine only gets about a 1000 out of his.
Bias ply tractor rears only last about 2500 hours and they are not sliding around like a skid steer does.
Gary
Just like any other tire, it all depends on the surface that they run on. Turning on dry concrete is alot harder on them then loose dirt.
Some tires just dont wear good either. Got a New Holland LS 170 bought new, 3900 hrs, on third set of tires. Runs on wet concrete all the time pushing cow stuff.
The operator is probably 40% of the issue. For instance when we unload cement trucks with a skid they have to turn around. I simply toss a couple shovels of dirt behind the truck and hose it down. Operators often are turning 90 degrees or a complet spin around when they could ease it around a larger less agressive route. Slippery manure will cut wear on tires, and make less stress on the skid. As with any machine managment is a large part.
We have a 751 bobcat with bobcat tires running over 2600 hrs now and still decent enough tread.We got it used with 1900 hrs at the time and we now use it on concrete pushing cow stuff too.It was owned by a rental company before we got it and was used on ashpalt quite often.Not trying to make any point here but just wondering why if yours runs on wet manure slick concrete why they wear so much?I expect that you have grooved floors,but still?
I agree with the operator answer. We have a fella that leaves the throttle pinned when he is running it. It binds up and bucks so much on dry concrete that it nearly throws him out of the darned thing. He actually knocked out one of the lights doing this. Had the thing bucking up and down til it shook it out of the housing. Less throttle, less agressive operation and turning, a little coal/silt/float/slop will make it turn much easier.
I watched the same bobcat operator pick up a bucket of salt to fill the spreader. He failed to level the bucket as he lifted and dumped much of it on his lap. I laughed heartily til the next bucket, he did it again. Then it was kinda not so funny. It corroded and froze the foot pedals, the throttle linkage, seatbelt buckle, etc...
Those tires can't be cheap.
Aaron
Thanks All,
So then from the response, at 1500hrs one would be looking at being on there 2nd set of tires as we have decomposed granite for soil in AZ.
Pea size granite that cuts pretty good as the soil is about 20% granite and after a rain the surface is all 1/8 sized granite.
So I was getting BS just not in the way I was thinking.
T_Bone
