Sleeve kit help
walleye
Hello just wondering if i could install a .040 sleve in a motor that has .083 pistons in it. Would the sleeves be too small and drop through or would they be snug. Thanks
(quoted from post at 09:07:23 04/19/11) Hello just wondering if i could install a .040 sleve in a motor that has .083 pistons in it. Would the sleeves be too small and drop through or would they be snug. Thanks
Do the math. The OD of the sleeve is .080 larger than a stock piston. Your piston is .083 larger than a stock piston. So your pistons are .003 larger than the sleeves and that is before any wear. You can get .005 over sleeves but I wouldn't bet on that working.
TOH
