OK. I have done some searching on here and just haven't found exactly the answer to my question. So here goes.
I was bushhogging with my 39 9N the other day and I heard a noise and poof, blue smoke from muffler and oil fill.
I hoped blown head gasket but after pulling head was disappointed. Number 2 cylinder had metal fragments laying on top of piston and the gap from the piston to the cyl wall was significant. In significant I mean like an eighth of an inch. It just seemed number two had this problem this bad. Looking more I noticed the sleeve was very much thinner and had even chipped at the top where it is even with the block.
So, I see I need to replace sleeves. Problem is two fold for me. One, I do not know which sleeves I have since these seem to be so worn I can't tell what thickness they should be. Two, in the rebuild kits I see the standard .090 and .040. and I keep hearing about the lip or flange. My sleeves do not have a lip it appears. They are just flush with the block. What gives? Any ideas?
BTW, I cannot make out the serial number on the block to be sure the engine is a 39. I have ID'd it by console, and other misc tell tell signs like no safty start switch and such.
Thanks all.
Thanks all.
