Sleeve removal suprise
Doug 13
When I removed #2 liner I saw rust. After cleaning the area I revealed a 4" long crack! Now what? I guess I now have a parts 8n.
Polish any rust and debris out of the
bore and slathered it and the new sleeve
up with the appropriate Loctite product
and move on.
(quoted from post at 21:15:34 10/11/22) When I removed #2 liner I saw rust. After cleaning the area I revealed a 4" long crack! Now what? I guess I now have a parts 8n.
I am a purist. If that block is torn down on the bench I would trash it and replace it with a good used block - preferably with thick wall sleeves and and the higher flow oil pump.
TOH
This post was edited by TheOldHokie on 10/12/2022 at 03:03 pm.
(quoted from post at 15:02:11 10/12/22)
TOH
After further cleaning the #2 block hole I see a large oval crack. Seems like it's ready to fall into the water jacket. Kinda unexpected problem. Ya, its junk. It has been a good project and I learned alot. Thanks for all your help TOH.
