Sleeve Removal
Frmldon
Are the sleeves in a 172 gas (Ford 881 tractor)engine pressed in or do they slide in? I am looking at replacing them along with pistons, and the ones presently in the engine do not want to slide out as easily as expected.
Thanks for you assistance.
I've read on this forum several times that you will need a puller to remove them. Some guys build their own puller from scrap metal and a threaded rod. Other guys have mentioned using a chisel to split the sleeve or running a bead with an arc welder down the sleeve to shrink it.
If you'll run a search for "sleeve removal" in the Archives of this forum I'm sure you'll get lots of ideas. I'm sorry that I can't be specific but both of my Ford Tractors are sleeveless.
