slow hydraulics
harley80
This last fall,I took my 52 8n apart and banged out the dents,straightened the fenders,filled in holes and repainted it. Changed all the fluids including the transmission/hydraulic,using the fluid called for in the book. This winter,while plowing snow (Michigan) My 3 point started lifting real slow, Only wants to lift at the very top of the quadrant. I have loosened the 4 bolts on the lift and adjusted them,but no change. Any ideas??
only lifting near the top of the quad is indicative of a worn cam pin / cam
time to pop the top.
as a test you could take the arm off the base and rotate it a lil past what would be the top of the quad. if it comes up better that pretty much confirms you need to repalc ethe pin then adjust it.
soundguy
