So, a while back I did a major rebuild on the hydraulics but due to a number of factors, I only just started to use the tractor again. I rebuilt the hydraulic pump and replaced the PTO shaft. I completely rebuilt the upper controls including a new lift cylinder and lift piston. The piston I installed was the one with the oring and leather backer. What a pain.
Anyway, I am now wanting to get busy with my implements but having trouble with leak down of the lift arms. If I turn the tractor off and stand on the lift arms, they settle down in about a minute. I just pulled the inspection cover with the dipstick. Looking in the inspection port with the tractor running, moving the lift control up and down I don't see any problems with fluid leaking from above or bubbles in the pump area. I did straighten the pump control arm and adjusted it as best I could to the instructions. The new scotch yokes have a little bit of a knock sound to them but hoping that will go away as they wear in or seat.
Any thoughts on why the arms leak down so quickly? If the lift cylinder is leaking past the piston seals, is there any way to know that before tearing the whole thing apart again?
This post was edited by Orion231 on 07/24/2022 at 08:46 pm.
