The lift ram arm in my daughter's 2N appears to have been driven up so far that it damaged the rear housing and lift cover. We are replacing the lift cylinder because it has been leaking down. While scraping the gasket residue from the rear housing, I found cracks and a raised hump where the lift ram arm 9N-545 apparently was driven into the center housing. After finding this, I examined the cover and found corresponding damage. With the cover off and the cylinder removed, the hydraulic ram arm can contact the cover in this area. Surely the lift travel is controlled in a way that would not cause the arm to bottom out. I can't think of anything that we have done in the short time we have had the tractor could have caused this.
The damage seems to have been similar in both the cover and housing, so the gasket does not appear to have been leaking. If I try to straighten the area, I am sure that it will break. That is to say fall apart, it is clearly broken, just not completely broken off. The only repair that I can think of would be to braze the cracks. That would involve collecting and reassembling the pieces.
Has anyone seen similar damage?
How can this happen?
Does anyone see a good reason not to use it as is?
This is the area where the damage was found:
The gap between the top cover and the ruler shows the depth of the damage in the top cover.
![mvphoto111964.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto111964.jpg)
![mvphoto111965.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto111965.jpg)
![mvphoto111967.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto111967.jpg)
