smd-ta hyd.
Having trouble with the Hyd. remote on my smd-ta, It has power steering with the priorty valve setup. The steering works perfectly but the remote will not pickup my implements. Could it be the relief valve in the tank or the priorty valve not set on the correct pressure?
Have you plugged a gauge into the remotes to see what pressure you have there Ya only need three gallon a min. for steering . What implements are you trying to raise and what size cylinders are you using . Your working with a low pressure system and a tractor that is old . Plus the fact that that SM/TA diesel has more then likely had extensive field testing thru it's life and your problems may be due to a plum slap wore out pump .
