smoke from engine
A tractor I acquired recently (Ford with the 172 cu in gas motor) smokes from the exhaust when running. No smoke when first started, but after it is running for a few minutes and starts to warm up is when it starts to smoke from the exhaust. Seems to be oil burning smoke. It's running smooth with good throttle response. Would this seem to be rings or valve guides letting oil into the combustion chamber? Hoping a head job would fix the problem but I'm not sure. I have not checked compression yet. Starts and runs normal other than the smoke.
Step one is to put synthetic 20-40 or 20-50 oil in it (assumes you are or it is warm. 15-40 will also do. if that reduces the smoking to a tolerable level it was cheap. Head gaskets do not cause oil burning. Valve guides smoke on startup, and when coasting down hills, not when in normal operation or steady pull. Jim
Mystic 15w50
What is your compression? My 52 8n has 90/95 on all 4 cylinders. It smokes when working and burns a qt. of oil +- every 5 hours. Has been for the 25 years I've owned it. Been running 20w50 oil since I've owned it. Starts easy and handles a 6' finish mower no problem. Yea, it needs to be rebuilt.
It's most likely worn rings. The oil rings can fail and it still have good compression.
Valve guides typically cause smoke on start up only. Rings smoke worse under load. Occasionally you find an engine so carboned up the oil can't drain back down from the top end, but in those cases the engine is beyond needing an overhaul anyway.
Are you sure the oil level is correct? Could it have the wrong dip stick, or the oil be contaminated with gas?
Do try the synthetic diesel oil, usually 15w-40 is the common choice. Diesel oil is better suited for the old flat tappet, non emission controlled engines.
You can always try going through the head first, that will need to be done anyway. All it will cost is some work and a head gasket.
Crank it and let it idle for 5 minutes for a number. Firewall the throttle. If you have a big puff of smoke, expect your valve guides/ seals to be worn. Oil is leaking down the valve stem into the combustion chamber....OHV vertical engine. I'd expect that first then rings. A compression test would rule bad rings in or out.
Why does it matter if an engine that's at least 50 years old smokes a little? Of course you could rebuild it and eliminate the smoke but unless it's burning a whole bunch of oil why bother? That couple grand you spent getting rid of the smoke won't make over a hundred dollars difference in the tractors value.
Change the oil, check the breather and use it. Oil consumption will tell you whether you need to do anything else or not.
I thought all old Fords smoked. Joking. Do you know the history of this tractor. Was it babied and idled a lot? Does it smoke only when it is run at low easy speeds for a along period of time or does it smoke at all speeds and loads? If it smokes only after it has been idling along for ten minutes or longer it could have glazed cylinder walls or the rings haven't seated from too much easy low speed use. You could try the sucking BonAmi through the carburetor trick if you do suspect glazed cylinders. The abrasive BonAmi powder will deglaze the cylinders.
I agree. Does your oil turn black early on after an oil change? Next time you do an oil change, run your finger in the drain hole in the oil pan and see if the bottom of the pan is full of sludge. If so getting rid of it may solve the problem.
I had a '63 2000D with 3900 original hours (proofmeter little tell tale rolling proving that it's working) when I traded it in this past January. There haven't been any wrenches on the engine proper, not even a valve cover removal to have the valves tweaked, that had varying amounts of smoke over the years in the exhaust even with a new oil change. I did add Sea Foam to the crankcase on a couple of occasions, like a pint to 6 gallons of oil, right before an oil change, running for half an hour or so, engine up to temp.
A big surprise came not long ago when I had a couple of hours job to do that put a (tolerable) strain on the tractor.....I worked it. The next time I went to use it it didn't smoke. Best guess was that rings may have been carboned up and the detergent in the oil plus stress of hard working caused the carbon to loosen, allowing the rings to expand back to normal and seal off the combustion chamber.
But I had that tractor since the early 80s at least, may have been sooner, and it smoked all that time enough to tell it was doing it, and the smoke was more blue than black so I wasn't having fuel injector problems. I knew I had good compression and injection because I never used a starting aid here in N. Tx. in the winter and the engine, after sitting for a couple of weeks or so usually, or more, would light off within 30 seconds raring to go. No way could I get enough heat in the cylinder to light off Diesel mist if I had low compression due to bad seating valves or worn rings.
So sir, let her rip is my advice unless you just need a place to spend money and/or need something to do.
What would you rather do first? Get out the parts cannon, spend a lot of money and time doing an overhaul, or do some diagnostics first?
Consider. You might spend several thousand on a full overhaul only to find out that a PCV valve was the problem.
I cannot stress it enough. Diagnostics first.
If it's been sitting for a while I'd do a compression test wet and dry. Change the oil and work it hard for awhile, watch the oil and monitor it but work it. Maybe a shredder or on a generator with a good load on it. If it's guncked up (technical term) getting it to temperature and working it often breaks up the gunck, if it's the walls are a bit glazed you might wear them in a bit. Tractors, especially the older ones were made to work. If you don't exercise them they get weak.
