smoke from vent pipe
Johnny50
Was plowing with a 50 yesterday. working it pretty good and noticed smoke or steam coming from the vent pipe. just saw this from the seat so don"t know how much. temp and oil pressure good. Is this normal for a small amount to come out of that pipe? What should I check?
It's normal for a small amount to come out,,If the tractors been setting for a while it may have some condensation built up in the crankcase which "steams" out a little when it gets warmed up good,
That's what the pipe is for,to relieve crankcase pressure.Put your hand under it when running,should be very little pressure coming out.If you can feel air pressue at 2or3 inches away you might be headed for an overhaul.The outside air temperature can make it look worse than it is.
there is a ventilator pump on the engine to lightly pressurize the crankcase, hence the vapor you see. perfectly normal. water vapor & combustion gasses that leaked by the rings. most of these rarely get to good operating temp so when they do the evaporation in the engine seems excessive sometimes due to build up.
