smta torque amplifier
PAUL SMTA
Hi,all.Just a question,new main clutch resurfaced flywheel and pressure plate plus throw out bearing and new torque amplifier installed.Followed the adjustments to the linkage to the letter.Everything workes great in all gears but when on a slight incline with main clutch disenguaged and torque lever in forward possition tractor will not roll back,move torque lever back and all if free rolling.Any input? Paul.
The MTA had minimal throw on the main clutch linkage, but it did have a stop bolt on pedal, may check that to see if you can gain a little more movement on clutch pedal. Otherwise, you can reduce the clearance just a little on ta clutch just make sure you maintain some. Maybe just and extra half or full turn on the link from clutch to ta making it a tight pin will do the trick. Ideally, when you push clutch in it should release ta same amount as pulling ta lever but this is sometimes hard to esablish when pedal pivots etc wear. Another thing, the book can be confusing, makes a simple adjustment way too complicated the way they measure things.
