SN# SIREAL NUMBER
JR.Frye
HAY OLD I told you here a while back I have CRS.
My other question was this tractor is I think a 1953 or 1954, I found this number on the right side of the block. AM 3858-6 what is this number?
You have understand I am new at this ok.If this is not the SN# then where is it on the tractor.
MANY THANKS:
JR.Frye
Serial number is on the left side of the rear end. If you lay your left hand on the left fender and your right hand on the seat and then look down there is a flat spot just under the brake cover with the serial number on it
MANY THANKS: Bythe way how was your day I spent all in the shaop working on the WD-45 and I got a lot done, I need to twest the bucket later it is about 3/8th of an Inch out of leavel, My shop floor is leavel, as you stand looking into the bucket the left side is higher, Thats an easy fix.
will Bud I got ta go my want'shelp Ill talk at ya later:
JR.Frye
Before you try to do much you might want to look at the tires and tire pressure. If one tire is bigger then the other or has say 10psi more in it that will throw the bucket out of level very fast
GOOOD MORNING: My GOOOD Friend.
I have done that and all the tires are the same
size and air pressure is the same.
I am thinking the person I bought the tractor from
might have hookd somthing and twested it.
I will get you some pics of the wd-45 today and post them for you OK. I gata go breakfast is ready.
MANY THANKS ,HAVE A GREAT DAY
JR.Frye
