Send a drawing of how it looks. Or a picture. There are several ways to mount a plow, but we need more info, and a picture or sketch.
Rustyj14.
Sorry about that trying to mount a snow plow would like a picture or a drawing so i can figure out how to mount it.Thanks
If it is a genuine Sears blade you just take the mule drive off the front of the tractor[the bracket that holds the two angled pulleys] and slide the blade's mounting bracket in its place.
There is a Craftsman snow plow available that has a long rectangular piece that goes under the tractor, and it has a tube about half-way back that goes up inside the tractor frame. Then a long rod goes cross-ways thru the frame rails, and thru the tube. I think the rectangular piece might go back to the trailer hitch plate, and connect to that with a large bolt.
At the front, there should be some brackets, and they would be connected to the tractor lift handle. Not sure how, but thats what it shows.
Get the model and serial numbers of the machine. go to www.sears.com poke around in there, and find the snow plow section. There are line drawings of the whole thing. And instructions of how to install the plow. That type shown is different than the one i described.
HTH: Rusty J.
