Snowblower HP
All depends on how fast you want to go, and how deep the snow is. My AC 7040 is set at 150 on the Dyno, and with the snow blower changed to the 1000 RPM shaft it pulls harder but blows MUCH better. Tractor has the Power Shift transmission, in really heavy snow first is fast enough. Lighter snow it will work fine in third or fourth gear.
On the dash next to the boost gage is payment for clearing the parents lane..
I have mine on a 70hp tractor. It handles it just fine, has never lacked power in my opinion.
As has been stated, it’s all about depth of snow and ground speed. Even if you have extra hp going too fast trying to move too much snow, you will just cut off shear pins. A 50hp tractor with a nice slow reverse gear can run that blower just fine. If the snow is too deep, hold the blower up some on the first pass, then come back with a second pass to clean up what’s left.
Depends on a few things. First is the blower itself. Some are more efficient at moving snow than others. Second is how fast is your travel speed. A 50hp with hydro transmission will probably move more snow than an 80 hp with the wrong gear speeds.
If you are asking about your new tractor, it has plenty of power. I am not familiar with it to comment on the ground speed. If it has an economy 540 pto speed that may give more travel speed options.
Don't know but my little Ford 1500 tractor with 17 rated pto horsepower has a Ford 715 5' 540 rpm snowblower that is designed to go with it. As soon as I weld up the 3 point bracket, get the round to spline pto adapter Monday, and then figure what size pto shaft I need, it will be running and waiting for the snow we may not get.
(reply to post at 22:20:38 01/30/21
Trying to push the snowblower into the snow faster
Than the rate of which the auger and blower can handle . It just adds stress into the PTO dives ,
Chain drives and auger .
Usually the problem is the travel speed being too fast
I have a 7 foot snow blower. Mine is perhaps a more low volume, or light weight, model. With a smaller fan. But it is two stage, cross auger and a separate fan.
80hp was more than needed. I was replacing bolts a lot, even some gears once.
The 27 hp of my little tractor is kind of low, but with the very slow reverse gear (3 reverse speeds) it works well for me.
The 45 hp tractor with only one reverse gear the hp was ok but it went too fast, so it wasn’t about the hp, it was about the speed.
I think my 60 hp tractor would be fine with it, it has 2 reverse speeds.
I tried to ask the same question you did when I bought the blower 35 years ago, and they wouldn’t give a real answer.
I think having a slow reverse speed is more important than just raw hp. It’s pretty easy to overload the cross auger by shoving too much snow, more then thr fan can handle. With my 80 hp tractor that made broken parts. With my 27 hp tractor it means the engine pulls down a little, and I step,on the clutch and let it clear. But no broken parts.
So, I guess it is kind of a complex answer.
Live pto, and multiple reverse speeds is a really good thing.
With that you can get by with less ho.
30-70hp is probably a wide but realistic range?
Paul
I run a 7' two stage with a 350 Farmall about 44 hp. The first pass in heavy snow can require some clutching to get through. So live pto is a must. After the first pass take a little less of a cut to minimize clutching. This tractor backs fairly fast. I have also used it on a 4010 gas Deere about 80 hp still have to clutch at times since I think the reverse gears are faster.
I have been running a 6'8" single auger 2 stage Allied snow blower with a 50 hp tractor for 36 years. It is a well matched combination.
Another thing about snow blowing, light fluffy snow blows MUCH easier than wet HEAVY snow does. PTO speed of 540 BARELY throws wet snow, just getting the PTO speed to 650-750 works well on wet snow, and why I switched my shaft to 1000. When compared to silo filling blowers, most 540 RPM blowers have a 56 inch fan, 1000 RPM blowers have a 40 inch fan. so WHY do 540 RPM snow blowers have the smaller 26 inch fan?? No wonder they plug easily in wet snow. With the AC 7040 on 1000 PTO, I can throttle back a little which HELPS slow ground speed, run the blower about 750 RPM, and shift up/down the power shift as light/heavy snow enters the blower. Faster fan speed does need more power though, but the snow REALLY FLIES out the spout if power is there.
any tractor with 1000 pto and use a 540 snow blower with adapter so the reverse is slow on tractor because you run 1200 rpm makes the best snow blower tractor for me. I have found that every tractor I have has to fast a reverse so you always ride the clutch. this solution solved the problem
I'd want 50 PTO HP on one with a good slow reverse gear.
I've run 78" on 42 PTO HP and it did fine.
You can take part cuts on 2nd pass in deep snow so no clutching.
1st pass you can carry the blower 8-12" off the ground, whatever the tractor will drive through as knock the height down.
Extra deep snow first pass I'd carry blow high and push into it unti revs drop, shove clutch in, wait for blower to clear, then go forward until a completely cleared spot, reverse and drop blower and clean up the section I carried blower high, lifting blower when I hit deep stuff again.
I never ride the clutch.
