flying belgian
There's your problem.
Hard to say without identifying that single spool valve. Some valves can be set up to operate single acting cylinders, that might be what you have. Also, some can be switched from single to double acting, that may be what your valve is, that is why I say the valve needs to be identified. There may be a screw on it somewhere to change it over. Does the handle move both directions equally and spring back to center?So, I bought a gauge this morning, the upper QC was 2000psi @ 1000rpm, the lower one was 0psi. I moved the cylinder to the FEL QC's and it worked perfectly. Do I need to replace the single spool, or is it fixable?
That handle was used on many Cross valves, so it doesn't help much of any. Numbers on the valve body will be more meaningful.I was looking at my posted photos and on the handle is printed Cross and on the opposite side is 4Z0030. I can also conclude that it is configured open center and power beyond,
I took a bunch of photos of the parts I can see and all that I can find is "Cross", "Made in USA" and "IN and OUT" embossed on the top, which is my bottom side. I have been searching and believe what I have is a CV1, Here is a diagram.
If you missed it in my last post (#28), I edited my reply when I noticed I had looked at the wrong picture and I think you may be right. As I posted in the edit pull that plug out and see if it looks like a 3-way or a 4-way plug using the drawing you posted.It looks tiny in that picture but looks the same to me in this photo. Do you have any suggestions. Massive damage to the spool shaft or maybe the relief valve or the wrong conversion plug?
