C.R.
I just finished a solar heater and im testing it out looks like it is working ok dont know how hot the air coming out is my thermomiter quit at 160 degrees anyone out there playing with this kind of stuff?
Yes, and it's amazing how much warm air you can push through one of those! One note--160F is getting to the point of combustion on some materials--you may want to increase your airflow to knock the outflow temperature down closer to 120F.
I have been thinking about trying to build one but haven't gotten around to it yet and but sure like to see pictures and plans of what you did and a matrilas (SP) list to boot.
I made it four by eight feet i used 3/8 plywood and 2x2 furring strips as a frame inside it is 4feet x 8 feet x 1 foot i put insulation around the inside and then i ran some four inch stove pipe back and forth i managed to fit ten pipes inside on the ends i used flexible dryer vent tubing i taped all of the joints together hit it with some flat black paint and i put a hunk of plexiglass over top i ran the in and out throgh the back total cost was about $250 materials list 2 sheets plywood 10 furring strips 2x2 stovepipes and flexible dryer vent insulation and the plexiglass i will post photo if i can figure out how
Tim what materials would start to burn around 160 degrees??? I know for a fact paper will not light till it has been heated to 451 degrees F. So what starts to burn that low other then your hand and body that is. Oh not trying to be smart here just want to learn more as to what it might be. Oh and the 451 is when it catches fire
Don't know of any combustion concerns, but 140F is generally considered the safe limit for touch temperature. Anything hotter than that should have a guard on it. Especially if there's little kids around it.
Old--some caulks and foam-based insulations can combust at that temperature, and even wood isn't recommended to be exposed to long-term temperatures above 120F. I'm not saying that the second the temperature hits 121 it's going to burst into flames, I'm saying that many materials degrade over time when exposed to those temperatures, possibly leading to problems up to and including combustion.
Ok now that you explained it better I understand what your saying. Sort of like pager if you put it in and oven and heat it to say 250 degrees it will dry out to the point it will fall apart but still not flame on and yep wood will dry out to a point it starts to brake down over time. Thanks for explaining what you where saying
Where did you place the assembly when completed? Roof, house side or standing independently? Father-in-law has been scheming an idea like this all winter and just now read this post. Do you damper it off when not in use? Interesting. Thanks for posting.
Hi Nedd I am going to put a couple of 2 or 3 foot legs on the solar collector and ground mount it i dont want to try to put it on the roof i dont damper it i have a couple of booster fans in it that i run to move the air i want to put a 12 volt P.V.pannel on it and 12 volt D.C. motors so if the sun is out the heat and fans both work and it wont need a thremostat
Congrats. Try to get the temp down. High temperature is meaningless. A candle produces 1500 degrees but little heat. My first much simpler collector has been running for 4 years now without a hitch. I'll send more details if requested.
