Solar heated pole barn.
Geo-TH,In
Outdoors it was 25 and sunny.
No wind and it was noon.
I was able to work inside without gloves.
No insulation. just solar heat. The air temperature wasn't 75. I had no cunventual thermometer to measure it. Floor temperature was between 39 to 41.
Floor never got below freezing.
I would say I got very lucky.
George
It went down Friday morning. Had about 36 hours of above freezing. Then 48 hours below freezing. Hot water and calcium was added. Temps never get below 32.
Today the roof was about 65+ no condensation.
So it appears if its sunny good chance it could be sprayed.
Your concrete will be fine .Concrete only has to reach 500psi (about what you would want just before running a finishing trowel on it)Before going thru a freeze thaw cycle. Sounds like you have passed that point.
I have to disagree---a freeze thaw cycle at only 500 psi compression will break the bond between aggregates--that why most specs call for 40* minimum for 6 days---then a gradual decrease in temperature to ambient is allowed
Big yellow thing in the sky.lol I don't think he has a solar system, per se. Jut the sun shinning on his steel.
2cents.
It is what it is. If it's a total failure I'll have to live with it or rip it up and do it again.
Going to let it cure for a few more weeks before I drive on it.
Working on work benches, shelves, wiring, and loft. I have enough to do now floor is down.
George
What color is the wall/roof steel? I used white on the walls and green on the roof, and then I sheeted the inside of the walls with OSB, it seems to stay warmer inside since I did that.
The cab on the Kubota got very warm in the sun too.
Last time I used it in the fall mulching leaves, it got so hot inside I had to turn on the AC. Outside temps around 50.
I have no plans to heat barn. Just getting out of the wind is great and better yet when temps are a little warmer because of the sun.
It was sunny, 25 degrees and I was working inside with just 2 shirts on and removed gloves. I didn't need to turn lights on either. The skylights are great.
geo.
If I worried about everything that could happen I wouldn't get out of bed.
Good chance I'll be dead before it Happens.
Roof is same as trim and wainscoting.
I decided on two colors to go with building on each side
Of barn.
George
OK, I misunderstood. I thought that you had intentionally installed some kind of passive solar system to heat it. :)
