tried a cold weather start, the engine turned slowly on the first start then nothing.
After that nothing happened.
-Replaced the battery. Still nothing.
-Took out the starter and bench tested it. The starter motor is fine
-Tested the solenoid, it made the "clunking" sound as it supposed to
-Figured the issue was therefor in the ignition wiring.
replaced the starter and solenoid and by-passed the ignition wire by using a screw driver and hot jumping
from the power terminal on the starter to the small ignition terminal.
The engine turned over but rather slowly. Still would not start.
-On repeated attempts, The solenoid terminal that leads to the starter began to overheat and glow red.
The engine is turning over slowly when the ignition is bypassed. So I assume I have to replace the wiring there.
But I should still be able to get the motor cranked up by-passing and hot jumping with a screwdriver.
is the solenoid not producing enough juice? Does it need to be replaced?
Thanks so much. God Bless
