Douglas Lloyd
I converted a 640 to 12 volt this weekend with the kit that Just 8N's sells. While I was at it, I figured I should swap out the 6v solenoid for a 12v.
Besides the heavy main posts. the old 6v solenoid only has one small post marked S, but the 12v solenoid has two small posts marked S and I. I connected the wiring up 12v negative per the diagram that came with the kit, with the S post connected to the safety starter switch on the transmission and just left the I post empty.
Trouble is the starter does not turn when I hit the switch. I jumpered the S post to ground and still nothing. When I bypass the solenoid and jump the starter straight off the battery, the tractor atarts and runs fine.
Did I get a bum solenoid, am I installing the wrong solenoid or do I need to wire this differently? I can put the original 6v solenoid back in place.
thanks,
Doug in east TN
thanks,
Doug in east TN
