GSRFord
My relatives 6000 has somehow had the shift cable come apart at the internal connection for the transmission cable end. Did it break? The upper end looks good. Can the lower half be fished out and reconnected. Does removing the cover over the the cam assembly get me in to see the problem? Any advice would be appreciated. Thanks
It is very easy to put it back together and adjust it so that it will stay together when you are looking at the manual.
The junction is in the conduit. Kinda hard for it to come apart without breaking. The lower cable stub should protrude out of the cover 2.75 inches. If it does not and you need to "fish" it out, you have bigger problems than a cable that came apart.
The cable does not stick out of the cover at all. I assume he shifted it and that is when it disconnected or broke. If I remove the cover can I see what is wrong? I do have a Ford manual for the later DDC transmission. Can the cable be replaced after removing the cover or is there more involved than that?
You should be able to see what you need to see w/cover removed.
If you have a replacement cable stub you should be able to repair it as well, unless a broken cable is not its only problem.
You will need to use the new cable stub in the PTO actuator while replacing the cover.
(quoted from post at 16:14:22 04/20/13) My relatives 6000 has somehow had the shift cable come apart at the internal connection for the transmission cable end. Did it break? The upper end looks good. Can the lower half be fished out and reconnected. Does removing the cover over the the cam assembly get me in to see the problem? Any advice would be appreciated. Thanks
The cable on my 971 was disconnecting. As CNKS said it is supposed to protrude 2.75 inches. mine was considerably less and was able to separate at the bottom end of the inside tube when in 10th. Simple adjustment took care of it.
Larry.I'm not sure what you mean about using the new cable stub in
the pto actuator when replacing the cover. I've never had the cover
off of one so maybe I'll understand once I remove it
(quoted from post at 11:02:32 04/21/13) Larry.I'm not sure what you mean about using the new cable stub in
If you don't have a manual that documents how to work on your transmission, then get one. There is a documented procedure for putting the cover plate back on so that the PTO actuator gets lined up properly. It involves using the shifter cable stub as a temporary alignment tool for the PTO actuator as you put the cover plate back on. All procedures for adjusting the lengths of the shifter and PTO cables need to be followed as well so that the PTO engages and disengages properly and the shifter handle can move the shifter control valve through it's full range of available gear positions properly, and so that the two halves of the shifter cable don't come apart on you again.
I currently have a shop manual supplement for 2000 and 4000 SOS transmission ddc model. I also have access to an I&T manual for the 6000. Will
these give me enough information? Would a reprint of the Ford
service manual for the 6000 be better? Thanks
