FarmerBlair
Hi, I'm trying to remove the control valve body from the SOS in my Ford 881. I planned on switching it out with a new one. Although I have all the attachment bolts out according to the shop manual, I can't budge the valve body. I tried pulling, prying, and gently tapping it to try and break it loose, but no success. I guess the max effort so far was using a 14" heavy screw driver and briefly prying upward with near full effort using the side of the transmission case as a pivot point. If anyone has had this off, is there a trick to the removal? I've re-checked the manual multiple times and I don't think I missed anything, but maybe there is something not mentioned in the manual. Or maybe it's just stuck to the gasket. If anyone ran into similar issue or any advice is much appreciated before I really start to muscle the thing. I worry about damaging something if get too aggressive.
Thank you!
Thank you!
