SOS Operation question
Hello again everyone. I am working on my late 1961 SOS 971 152xxx tractor. The tractor shifts through all gears well with no problems at all, but in Park, if placed on an incline it rolls down. Is it supposed to do this or should it lock in place? It is a 312259 transmission casting and the fluid level is good filter clean. I adjusted the bands according to the manual and it still shifts everywhere fine, but no park hold. Any suggestions? Otherwise kinda liking this machine.
Thanks.
Jason
The transmission should lock the driveline when in Park though there will likely be a delay prior to engagement.
Dean
B2 & B3 make Park on that machine. These are spring applied. It seems odd that all ratios work and it still rolls away in Park. Are you sure you have the proper manual? Something surely sounds off on band adjustment to me.
Many SOS operators have reported that the tractor will roll a bit after P is selected. The most common cure is to place the selector in 5 (IIRC) and then quickly move it to P. Fortunately I've never had this problem with either of my SOS tractors (971 & 5000).
I use my 971 quit a lot in the summer. Before the SOS warms up, it will creep for a second or two in park, but once it gets warmed up it is pretty much instantly in.
are sos transmission tractors equipped with lockable
brakes? been a few years since i owned one but i
believe my 64 4 cylinder diesel was not equipped
with lockable brakes.
(quoted from post at 15:41:45 12/08/12) are sos transmission tractors equipped with lockable
the early 01s were, if not all the 01s. the 4 cylinder 000s were not. I can't speak to the '65 - '74 models
Tough to do on the SOS tractors without brake locks.
For this very reason, I installed brake locks on my 64 4000 SOS.
Dean
Thanks for the responses everyone. I will try the 5 to P trick and
see if it works. If that does not, I will look at readjusting the
linkage. I will report back after I give it a try. It does have the
brake locks, but was afraid I was damaging it.
Jason
(quoted from post at 13:08:29 12/09/12) Thanks for the responses everyone. I will try the 5 to P trick and
Getting it warmed up makes no difference?
Jason
(quoted from post at 15:08:29 12/09/12) Thanks for the responses everyone. I will try the 5 to P trick and
Jason
readjusting linkage?
(quoted from post at 21:50:17 12/09/12)
Jason
The cable might not be allowing it to get fully in to park?
Jason
