SOS Transmission on Ford 6000
Brita
Anyone know how to tell if the metal seals are correctly installed between #1 clutch and 2, 3. The seals are on the planetary shaft and the shaft the goes through the planetary. Tractor is split at the rear end. Any help on knowing how to get them installed without wrecking them and installed correctly would be appreciated. thx
These are oil ring seals inside the transmission in-between #1 clutch and #2,3 clutch. They are metal ring seals to guide the flow of oil to different parts of the transmission inside and a seal drive won"t work on them.
Contact me by email. I know a gentleman that knows these things inside and out. I just don"t want to put his info on here with out his permission, but I can get you into contact with him.
His Dad and he owned a Dealership when these tractors where new. He did the service work on them.
