Source for LED bulbs?
Ultradog MN
Location
Twin Cities
Does anyone have a source of led bulbs for this type of light?
These housings are original on my Ford and I would like to put led bulbs in them.
I need 4 of them.
Thanks.
have you checked the voltage you are getting to the lite. Just look up led lites 6v and you will find lots of them
I know they are here but don't know who sells them.
If I was needing any of the following things I could drive right there - probably within 15 miles and get it.
1/4 beef, half a hog, live chickens for butcher, engine rebuilders, exotic chocolate, every conceivable kind of JIC fitting, custom hyd hose, hyd cylinder seals, specialty paints and coatings, copper, brass, aluminum, 4140 steel, 303 or 304 stainless billets, I beams, channel and angle iron, square tubing, round tubing, aircraft tubing, delrin, metal lathes or milling machines, wood working machinery, clutch and U hoint stuff, electric motor rewinding, wedding dresses, Cummins engine parts, furniture, mattresses, mexican, asian, african, middle eastern or kosher grocerys, guns and ammo, combination safes, marine plywood, exotic wood, 3 phase stuff, throwing knives,fire brick and decorative brick, boiler retubing, 900-20 tires, seals and bearings, go cart or hot rod parts, racing tires, opera, theater or sports tickets, fancy bicycles, D9 Cat dozers, Kenworth, Mack and Peterbuilt trucks, Harleys, Yamahas, Airstream travel trailers, boats and motors, scientific instruments, thrift stores, pawn shops, used and U pull auto parts, hot asphalt, ceramic tile, I joists, LVL beams, 16x16x 24 ft Douglas Fir beams, pallet racking, floor jacks, way oil, stellite and hardfacing welding rods, hilift jacks, radiator rebuilders, osha approved rigging equipment, new and used Wisconsin engine parts, pallet jacks, forklift repair, places that rent anything and everything, garage doors, architectural antiques, fancy lighting fixtures, floor buffers, Red Wing boots, nursery stuff (both tree and baby type), cardboard boxes made to size, barrels of antifreeze - new or used, dental implants, computers, appliances, security cameras, hearing aids, chain saws, concrete drills, gold coins, puppys, kittens and ducks, pole barn tin, rolled roofing, artist supplys, snow skis, trailer axles, diamonds and jewlery, taxidermy stuff, wine making equipment, sand blasting equipment,squirrel traps, reloading supplys, back braces, micro brewed beer, vacuum cleaners, firewood, sod, fire extinguishers,scaffolding, and that's just the short list off the top of my head.
Make sure the lumens at
Least 1200 or dont
Bother .
This company carries a high output LED lamp for every 6V ,
12v and 24V application . In any semi common base and any polarity . Even the 3000K colour to mimic the original incandescent lamps .
I have upgrades most of our two cylinder fleet with these .
http://www.classicautobulbs.com/automotive-light-bulbs/antique-vintage/6volt_led_bulbs.htm
(quoted from post at 11:27:40 08/07/21)
I sure fail to see the point of your last post.
Hdonly, on modern view you can click on an a box to view all of someones posts, and then you would see the clever point.
