Source for Remanufactered Ventilator Pump
Had the ventilator pump go out on my 66' gas 4020. Im looking for a remanufactured one from someone who has a good history or has been reliable, I'm out of central Indiana. Been looking on the inter web for one and haven't had much luck
take it out of the block and pull the gear off and reinstall then cap the fittings where the line hooked up and don"t worry Deere had a bulletin out on this it is not needed
I"m wondering what could go wrong?
As you know, it"s essentially a paddle wheel that doesn"t even contact the housing, with the governor shaft going through it.
I took off the housing to replace the gasket around it, slid the housing back on and turned the tractor on and it tore apart the paddle wheel. I obviously bumped the paddle wheel unknowingly while putting the housing on. Hence was not a good day.
