1950 8n front dist. 6v. No spark to the plugs. Removed distributor did testing with multimeter, everything checks out there. With key ON I have 6.24v from battery ground to each of the three leads on the resistor. With key ON I havev6.24 v from battery ground to top of coil.
I tried jumping from pos. battery side to coil (when I first touched lead wire to bat. I got a little spark.) and it fired right up. Disconnected and it shut off, fine. Picked up my tools and tried jumping again so I could move the tractor up to the house and it wouldnot start or even fire, I couldn’t even get that little spark when I touch the jumper to the terminal.
I don’t know much about electrical systems so I’m just going by advise I’ve found on here. But, I’m lost as to what to do now.
Any advise would be appreciated. Thanks in advance.
