Pete Hall
When i pull a sparkplug wire and hold a gap from the dist.cap the miss goes away.I know this has been discussed many times as to the problem but i cant seem to find the forums on this problem.Could you guys help me out AGAIN.May be i can remember this time.
Thanks again,
Pete
Holding the wire back from the plug makes a home-made "spark intensifier" that will fire a "dirty" sparkplug or compensate (sort of) for a weak coil.
It will also fire a lean mixture better.
So the possibilities are...
bad sparkplug
weak spark
lean mixture (if only one cylinder of a multi-cylinder engine this could be from a leaky intake gasket or valve problem.)
Spark intensifiers
Champion's "EZ Start" sparkplugs for outdoor power equipment have a "booster gap" built in.
Sounds like the same principal to me!
Now I gotta say, Bob, it takes a real "purist" to make the principle/principal distinction. I'll bet we would have just let it sliiiide right on by. . . LOL
Bob's from the land of good schools and low unemployment, so he knows some of us will hold him to a higher standard.
You coming "home" this summer, BF? I'd like to meet you sometime when you're in the area.
